Make your own ABS colour masterbatch for filament extrusion. October 20, 2013 05:54AM |
Re: Make your own ABS colour masterbatch for filament extrusion. October 21, 2013 08:25AM |
Re: Make your own ABS colour masterbatch for filament extrusion. October 22, 2013 01:50AM |
Re: Make your own ABS colour masterbatch for filament extrusion. October 22, 2013 02:45AM |
Re: Make your own ABS colour masterbatch for filament extrusion. December 21, 2013 10:18PM |
Re: Make your own ABS colour masterbatch for filament extrusion. December 22, 2013 12:29AM |
pourcirm
Have you run this through a printer yet? I'd be curious to know how well it goes through the hotend and what the finish and strength of the parts printer with it are.
Re: Make your own ABS colour masterbatch for filament extrusion. May 15, 2014 05:17PM |
Re: Make your own ABS colour masterbatch for filament extrusion. May 16, 2014 12:13PM |
Re: Make your own ABS colour masterbatch for filament extrusion. June 03, 2014 03:51PM |
Re: Make your own ABS colour masterbatch for filament extrusion. June 19, 2014 05:53PM |
Re: Make your own ABS colour masterbatch for filament extrusion. November 28, 2014 03:01AM |
Re: Make your own ABS colour masterbatch for filament extrusion. December 24, 2014 08:49PM |
Re: Make your own ABS colour masterbatch for filament extrusion. May 04, 2015 03:26PM |
MileHigh3dII
I've been doing something similar. I use acteone and some ethyl acetate as the solvent. I do about 100g of ABS and 150 grams of Acteone and stir it up with a wooden popsicle stick. I stir it up a few times over 12 hours. When it seems like I have it pretty well dissolved (really check the bottom) i add the ethyl acetate. It is in hardware stores as "M.E.K Substitute". I'd rather have MEK, but this seems to help slow down the evaporation of the acetone to make it easier to work with. Stir it up and add pigment. Stir it up to get the pigment dispersed. Then I pour it into a sandwhich plastic bag with a sliding seal on it. Evacuate the air out of it and seal it. I then 'massage' the bag to make sure that there aren't any pigment agglomerates in the mix. Spend a few minutes doing this, trying to 'smear' any soft resin bits that aren't dissolved or pigment agglomerates that aren't dispersed. Work the mixture into a corner of the bag with your hand above the material. Then I use the bag like a cake icing dispenser by snipping a small 1mm or so hole in the corner of the bag. Then I squeeze the bag to expel a thin stream of liquid concentrate onto an aluminum foil sheet (I'm trying waxed paper tonight). The key is to move quickly to lay down a thin (think the size of the ABS pellets) stream. I think the ethyl acetate helps to keep the stream 'open' and not skin over. I still get some clumping, just drag the nozzle a bit and it will fall off. If the pigment isn't dispersed or the resin totally solvated, it can clog the hole, causing issues.
Let the solvent evaporate overnight. Then when its warm and the sun is out, I place it outside to help 'dry it out more. Even with all the solvent out, it can seem a bit 'spongy'. I peel it off the foil and have done everything from put it into a blender or just taken a knife and chopped it like a bunch of green beens.
I've been using inorganic pigments and done pigment to resin of about 1:1, and that seems to work. I aim for about 2% pigment when I mix the resin with the color concentrate.
If You Can Read, Thank A Teacher. If You Can Read It In English, Thank A Veteran That's what you do in a herd: you look out for each other. - Manny from Ice Age |
New to 3D printing, not new to 3D or tinkering. LulzBot Taz 5 Generic Chinese 50w 300x500 Laser Cutter/Engraver (Ebay:171066211150) Corel X7, Photoshop CS6, Lightroom 4, Modo, Hexagon, Bryce, Poser |
