PG35L stops mid print
Posted by Flyer2
April 03, 2014 05:11AM
My pg35l extruder works fine on small prints but when I run longer sketches it stops extruding after about 1.5 hours. I thought it was the nozzle plugging up but this last time after killing the print I sent a manual extrude command and it worked fine. I'm thinking maybe the driver current setting is wrong. Has anyone else experienced this? I assume I should start by lowering the current?
Re: PG35L stops mid print
April 04, 2014 09:55AM
Turned up the pot a little and it's working fine.
May 18, 2014 02:48PM
make sure you have a fan on the motor too
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
