E3D Extruder.
September 10, 2014 08:39AM
Hi, somebody use E3D extruder? Is it good quality? Need I use a fan?
Re: E3D Extruder.
September 13, 2014 02:57AM
karagad
They are absolutely top notch Quality and the easiest to actually extrude that I know (You can hand push PLA thru them at 185 degrees with minimal hand pressure) they come with a small fan and housing that clips over the body and the thing is so efficient that with the nozzle at 235 degs the top of the housing is still cool to touch.
Don't hesitate just buy one they are great.
they is a good review of them Here Page 41 is where you need to start reading.
HTH
Doug
Re: E3D Extruder.
September 13, 2014 06:16AM
Thank you, Is it still good without using of fan?
Re: E3D Extruder.
September 13, 2014 09:30AM
As much fan as you can get on it is better. I changed to 40mm fan from the dinky 30mm fan.
Re: E3D Extruder.
September 14, 2014 10:54AM
karagad
I think it's better to say that it's not designed to be used without a fan. The heat would travel up via the metal heatsink and jam up the extruder. Any reason why you would not want to put a fan on?
Re: E3D Extruder.
September 14, 2014 12:04PM
I want to buy it on aliexpress for $22, without fan. And there is one for $60 on EBay with fan.
Re: E3D Extruder.
September 16, 2014 09:02AM
you can pretty much use any fan of the similar size, shouldn't cost more than a couple of bucks for a cheap one.
Re: E3D Extruder.
September 27, 2014 12:47PM
karagad
That is not an E3D, and almost certainly won't work. Buy genuine, or buy twice.
Edited 1 time(s). Last edit at 09/27/2014 12:48PM by greenman100.
