Arctic Freeze water cooled hot end
Posted by metzindustries
January 01, 2015 10:53AM
Hi we have been working on a water cooled print head most of the year and it is finally done
It comes with files to,print a water pump, direct drive extruder, and radiator.
The extruder I have been using the design for months in both aluminum and printed plastic.
I regularly print polycarbonate with it. It is all metal, except for the pneumatic fittings. Tapped to take a m6 thread K type thermocouple.
When used with aquarium pump it is totally silent. I regularly do 60+ hour continuous prints with it.
It works with direct drive or Bowden.
Edited 1 time(s). Last edit at 01/01/2015 10:59AM by metzindustries.
Re: Arctic Freeze water cooled hot end
February 04, 2015 06:07PM
Looks good smiling smiley
What's it called?
Edited 1 time(s). Last edit at 02/04/2015 06:08PM by Tekwizard.
March 08, 2015 11:13AM
Questions:
What happens when it fails- pump fails or tubing gets pinched/clogged, pierced/cut, etc.?
Will the pump motor last longer than a typical cooling fan motor?
March 16, 2015 12:50PM
Aquarium pumps are super reliable and will work 24/7 for years.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
March 21, 2015 08:52AM
Adding pumps, hoses, reservoirs, heat exchangers, etc., adds a lot of cost/complication that would have to justify itself in terms of performance.
What advantage does water cooling offer over air cooling?
March 29, 2015 07:02PM
Justify???
If I have to start justifying all the 3d printer parts and pieces around my house, I'm going to have hell to pay with my wife...
smiling smiley
April 06, 2015 10:15PM
I think this is most useful for a printer that is in a heated-enclosure where the ambient air is not all that cool to begin with. I am printing PC now and my chamber is at 60C and so I think water-cooling would be interesting.
[www.matter-replicator.com]
May 06, 2015 02:22AM
It is because the temp transition is much sharper than with air cooled. As far as complexity, it adds in 2 hoses, a tank and a aquarium pump. You can also use a laser water chiller. Some people have used CPU coolers although I have found the pumps are not very strong on those.
Regarding pump stoppage or operation without the pump running.
It will jam after awhile as heat builds up. Most often you get the polyethylene hose melted in the fittings.
One cool feature that it will do, is that you can leave the hot end hot for a extended period of time without a jam.
I have left it on 15+ hours and resumed printing without problems.
I would reccomend using automotive anti freeze instead of water to keep mnold from growing in the system.
November 24, 2015 09:32PM
Well, it would be nice to have one to test.
Still waiting mine after 3 monthes, paid in full and no answer to my last email.
June 12, 2016 05:40AM
My solution....2000 hours tested....
[www.facebook.com]
