Miniature extruder? January 06, 2015 10:37PM |
Re: Miniature extruder? January 07, 2015 07:43AM |
Re: Miniature extruder? January 08, 2015 02:22AM |
Re: Miniature extruder? January 08, 2015 05:32AM |
dc42
Note that 5-wire stepper motors are not suitable for use with standard Pololu and similar stepper motor drivers. Choose a 4 or 6 wire stepper motor.
Re: Miniature extruder? January 08, 2015 11:44AM |
Re: Miniature extruder? January 09, 2015 11:21AM |
Re: Miniature extruder? January 11, 2015 05:04PM |
Yvan256
"DC5V 2-phase 4-wire Gear stepper motor Full Metal Gear Stepper Motor"
Specification:
Step Angle: 18°
Reduction ratio: 100:1
Phase Resistance: 12 Ohms
Voltage: 5V
Weight: 15 grams
Shaft: 3mm
Gears are made of metal.
Steps per rotation: (360°/18° = 20, multiplied by 100 with the gears) 2000 steps
Wiring Connection:
Red: A +
Orange: B +
Black: A-
Brown: B-
[www.ebay.ca]
Re: Miniature extruder? January 11, 2015 05:11PM |
Yvan256
Yvan256
Specification:
Step Angle: 18°
Voltage: 5V
Next step is going to be testing this same motor but with an A4988 stepper driver and 12V, however I'm not sure what the current limit should be for this stepper.
As it specifies 5V and 12 ohms per phase, the A4988 current should be set to at most 5/12A per phase = 417mA.
Re: Miniature extruder? January 11, 2015 06:19PM |
Re: Miniature extruder? January 12, 2015 03:43AM |
Re: Miniature extruder? January 12, 2015 09:55AM |
dc42
If you will be using a standard stepstick driver board, then the current is defined by the voltage on the pot wiper, which you can measure with a multimeter. Read the driver manual to determine the relationship.
Re: Miniature extruder? January 18, 2015 06:07AM |
Re: Miniature extruder? January 18, 2015 07:53AM |
Re: Miniature extruder? January 18, 2015 08:40AM |
Re: Miniature extruder? January 18, 2015 10:06AM |
Chri
I just measured the coils again, it seem`s that i already have blown one coil
Chri
Re: Miniature extruder? January 18, 2015 04:24PM |
