I need base settings for wades extruder.
June 02, 2010 04:19AM
I need the E_STEP_PER_MM value for Wades Extruder...? Thanx MB
Edit: oh and how many degrees per step is your motor.... mine is 1.8
oh and my nossle is 0.5mm
If your setup differs i can do the math... i just need a base setting... your nossel size and motor's degree spec...
Thanks a BUNCH MB
Edited 6 time(s). Last edit at 06/02/2010 07:20AM by Mdbaughman2.
Re: I need base settings for wades extruder.
June 02, 2010 10:22AM
Check the very bottom of this page:
[objects.reprap.org]
There is an xls/ods document that you can punch your numbers into to get the steps/mm for the firmware.
[www.binaryconstruct.com]
June 02, 2010 01:53PM
Jeff,
Thanks for the info. I guess I over looked it when I was on that page... Thanks a bunch MB
June 30, 2010 02:25AM
I also have a new Wade/Nophead extruder, and am a total noob.
Using the spreadsheet is great - but which steps_per_mm do I enter? steps_per_mm of feedstock? or filament?
And the "Ideal Head Feedrate" - This should be entered into the reprap host preferences?
Lastly - how fast should I be capable of extruding?
After experimenting for a while, I can extrude - but very slowly.
Thanks a bunch.
July 15, 2010 05:39PM
Check this out, its a great writeup on this calculation by The Brokentoaster Blog. Be sure to read the comments too.
Calculating E_STEPS_PER_MM for the Reprap Mendel
Edited 2 time(s). Last edit at 07/15/2010 05:41PM by jeffpark_.
