Thermal Fuses for Heater
Posted by damonb
June 21, 2010 12:20AM
Are there any thermal fuses that operate in the 500F temperature range.
I would really like to have a failsafe that kills the power to my heater
if something goes wrong with the temperature control.
The closest I have found are replacement thermal fuses for coffee pots
that open around 400F.
VDX
Re: Thermal Fuses for Heater
June 21, 2010 03:08AM
... you can apply lower-temp thermal fuses when positioning them not directly near the heating zone ...
Viktor
June 21, 2010 06:54PM
I use a non welded thermocouple for temp control, and have the software look for out of range temperature values. If either of the thermocouple wires come loose, or things get too high, I shut down the heater. If you're using a Makerbot motherboard with an ATX power supply, you can even turn off the power supply automatically.
Wade
September 20, 2010 05:23AM
operate = open circuit, right? This one is close:
[www.digikey.com] Thermal fuse (464 degF 240 degC)
