tips on diy filament extruder April 01, 2016 02:57PM |
Re: tips on diy filament extruder April 01, 2016 04:42PM |
Re: tips on diy filament extruder April 02, 2016 01:32AM |
Re: tips on diy filament extruder April 02, 2016 06:43AM |
Re: tips on diy filament extruder April 05, 2016 03:08AM |
Frans@France
Just move your extruder to a higher position or make a smaller nozzle would help in getting the correct diameter. Lots of info to be found on the filastruder forum about this
Re: tips on diy filament extruder April 05, 2016 05:34AM |
Nothing about the filastruder that can not be used for your own extruder when using the same gravity based width control technic. If you're extruding ABS then nozzle size, temperature and height is important to get to the final width including correct placement of the fan and controlling the stability of the temperature. Also your type of ABS and it's specifications like flow rate will influence the optimal settings.Quote
Gaou
i had it closer to the floor and then i raise it up a bit. it didn't help . also i had 1.35 hole and then i went to 1.7. that didn't help either. the filastruder forum doesn't have diy builts ( or at least i didn't found any ) buy only the the filastruder extruders.
Re: tips on diy filament extruder April 05, 2016 01:54PM |
Frans@France
The lyman uses a 4.5mm nozzle.
Re: tips on diy filament extruder April 05, 2016 02:10PM |
Gaou
Frans@France
i didn't knew that. what diameter the filastruder use ? and if you don't mind asking what do you use?
when i started i started with 1.2 going up to 1.5 that i drilled today. in the past i even used 1.35 1.25 1.45. but i saw that this is not so important as it changes as the temp change . .
Re: tips on diy filament extruder April 07, 2016 01:22PM |
Re: tips on diy filament extruder April 08, 2016 01:40AM |
IanJohnson
With any filament extruder you will need to discard the first few feet of filament. The diameter won't be consistent until the conditions of extrusion reach a steady state.
IanJohnson
Once it has started to coil on the floor, is the diameter consistent?
IanJohnson
It works best if there is enough open space below the extruder that it can coil in a circle with the nozzle at the center. If there are table legs or other things under the table for the filament to bump into, it will have a hard time maintaining diameter.
Re: tips on diy filament extruder April 08, 2016 06:43AM |
Re: tips on diy filament extruder April 08, 2016 08:03AM |
Re: tips on diy filament extruder April 08, 2016 12:54PM |
Re: tips on diy filament extruder April 08, 2016 01:00PM |
Then you would be close to the stratasys usd200,- filament specs and no the standard usd 20,- rollsQuote
Gaou
what ? is it true ? i want the filament to get to 0.005-0.01 difference .
Re: tips on diy filament extruder April 08, 2016 01:08PM |
Re: tips on diy filament extruder April 08, 2016 02:16PM |
