DIY Filament Extruder May 23, 2016 03:45AM |
Re: DIY Filament Extruder May 23, 2016 04:31AM |
Admin Registered: 18 years ago Posts: 14,148 |
Re: DIY Filament Extruder May 23, 2016 05:41AM |
Re: DIY Filament Extruder May 23, 2016 06:04AM |
Re: DIY Filament Extruder May 23, 2016 06:20AM |
Re: DIY Filament Extruder May 23, 2016 07:19AM |
makerbro88
s it seems the 16mm auger fits good in the brass end tap , but the pipe fitting is too narrow to fit the auger bit....
Should i buy myself a set of tapering stock to cut a winding into a seamless steel barrel? or do i grind the 1/2 inch fitting a little bit? or do i just buy a 3/4 inch pipe?
Maybe some of you encountered similar problems.
Any advice of how to do it, or not to do it is appreciated.
decided to go 3/4 because I thought that that would be easier then grinding the 1/2 inch. Looking back the grinding might have been a beter (easier) plan
Re: DIY Filament Extruder May 23, 2016 08:40AM |
Re: DIY Filament Extruder May 23, 2016 12:30PM |
working on it for almost 18 months now...
Re: DIY Filament Extruder May 24, 2016 02:03AM |
Re: DIY Filament Extruder May 24, 2016 02:14AM |
