Print raft only? March 05, 2011 05:52PM |
Re: Print raft only? March 06, 2011 12:56PM |
Admin Registered: 15 years ago Posts: 1,470 |
Easiest way: create a box the size you need and say 1 mm thick. Set skeinforge to print a raft, and then in the carve settings set the layers to go from 0 to 1. Under Raft set the Object first layer flow rate to 0, and turn off the Fill plugin. That way it will print the raft, then try to print the outline of the first layer but with no flow, and then it will be done.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
