How to adjust UV resin viscosity ??
Posted by EGPMAX
July 04, 2017 10:28PM
Hello
Please I need help confused smiley
I have uv resin the viscosity is 3000 CPS ,I need to adjust the viscosity of resin to be 250 CPS How can I do this
without any change in chemical properties ?
THANK YOU
VDX
Re: How to adjust UV resin viscosity ??
July 05, 2017 05:39PM
... without a solvent only heating can reduce viscosity - but above 60degC the composition can change, so the curing parameters will change too ...
Viktor
July 05, 2017 11:55PM
Hi, I really thank you for this information, what is your Recommends
About the best solvent for UV-cured liquid acrylic urethane methacrylate adhesive , has no negative effect on chemical composition , less odor, clear
Also if I use heating The resin will return to the same first viscosity when it completely cools ?
Is there any custom machine to reducing the viscosity?
thank you so much
Edited 1 time(s). Last edit at 07/06/2017 12:16AM by EGPMAX.
VDX
July 06, 2017 02:54AM
... depending on cmposition, temperatures below 55degC won't change the behaviour after cooling down.
I'm printing (jetting) pastes with even higher viscosities, but the valve with controller is pretty expensive (around 8000€) eye rolling smiley
Here some videos, showing the "printing" and the results:
[vimeo.com]
[vimeo.com]
[vimeo.com]
[vimeo.com]
Viktor
