Poll: what are your hotend heat up times?
Posted by VladCronos
April 17, 2018 07:48AM
Hello everyone,
Would be interesting to hear what is your hotend heat up times.
1. 25-200
2. 25-350
3. 25-500 (if applicable)
Here is my data:
1. 20s
2. 35s
3. 50s
I really want to know what industry average is and what is considered standard.
Thank you in advance for participating in my poll smiling smiley
Edited 1 time(s). Last edit at 04/17/2018 07:49AM by VladCronos.
Re: Poll: what are your hotend heat up times?
April 17, 2018 02:19PM
You could reach 500°C in 10 sec, but then it would overshoot a lot.
I usually wait 60sec after it reached temp to let it settle down.
April 17, 2018 06:14PM
I don't think it is at all possible to reach 500C in 10 seconds, unless you are powered by uranium grinning smiley
VDX
April 17, 2018 06:55PM
... you'll need some more power and "thermal coupling", than with common heater setups -- but otherwise not really problematic to get even higher temps in shorter times.
Some of my "advanced heaters" draw up to some kW of power ... and the fastest (laser-based) are used to melt the tip of a 0,5mm thick metal wire in some milliseconds winking smiley
Viktor
April 17, 2018 09:06PM
Victor, we are talking here about consumer 3D printers, not about lasers etc. I understand that bigger more powerful heaters exist lol. My heater is 20mmx6mm tube that works perfectly fine with stock Duet board without requiring extra MOS. Not talking about some oversized setups that are heavy. My printer does 300mm/s with perfect quality, because the whole carriage is extremely light.
Edited 1 time(s). Last edit at 04/17/2018 09:08PM by VladCronos.
VDX
April 18, 2018 02:28AM
... we're talking about DIY-heaters too - some years ago we've tested with different heating technologies and thermal isolation.
The simplest extruder heaters were made with enamelled wire, wound around a tube and thermal isolated with ceramic clay ...
Viktor
