Thermister (Why are we cutting into the barrel?)
Posted by Anonymous User
Anonymous User
January 10, 2008 11:07AM
I see two ways of mounting the thermister. One cuts into the tip, and one cuts into the barrel. Why does this part need to be below the surface of the metal? Can
Re: Thermister (Why are we cutting into the barrel?)
January 10, 2008 12:00PM
If you hold a thermocouple to the extruder barrel you will find that the reading varies wildly where you put it, how hard you press etc. Embedding it seems like a good idea to get an accurate reading.
January 10, 2008 01:20PM
> I think I would like to just buy a nut that fits
> over the barrel. I could then drill a hole
> through the side of that nut and JB weld the
> thermister so it is in that hole sitting against
> the barrel.
Similar idea using a penny: [forums.reprap.org]
My current configuration is a thermistor wrapped in PTFE tape and strapped onto the barrel using a piece of twisted wire.
