Where can I buy this nozzle in the US?
Posted by SCphotog
July 18, 2011 10:19PM
I am looking for a place in the US to buy this nozzle. I have everything to make this hot end except the nozzle.
Edited 1 time(s). Last edit at 07/18/2011 10:32PM by SCphotog.
Re: Where can I buy this nozzle in the US?
July 18, 2011 10:25PM
July 18, 2011 10:27PM
I posted the photo. Not sure why it didn't show up.
Here is the link to it. [reprap.org]
July 19, 2011 11:15AM
Hello,
I have some of the parts, for them, and the raw materials to make what I don't have.
I can make the following kit, for you, for $48.00:
PTFE thermal barrier
brass nozzle
PEEK block
aluminum heater block
5.6 ohm heater resistor
100K ohm resistor
They work, however, the PTFE thermal barriers do tend to break as the wall isn't very thick at the root of the threads.
I have been working on this design: [reprap.org]
I doesn't have the weakness nor complexity of the "Geared Extruder Nozzle". However, while it works, the mean time between failures is unknown. So far, it has successfully printed out a couple of PRUSA kits in ABS. PLA works, but requires some serious tuning. Hopefully, the experimental heat sink will make it easier to print PLA.
The main disadvantage is that the brass nozzle requires considerable machining...and is more expensive as a result.
Regards,
Brian
> except the nozzle.
> [reprap.org]
> le-parts.jpg/688px-Nozzle-parts.jpg
July 19, 2011 11:42AM
The nozzle in your picture looks a lot like the one that TechZone sells - theirs is made from 7mm brass rod, and has a standard 7mm thread.
July 19, 2011 12:17PM
I have the PEEK Sheet, PTFE Rod, Brass bar stock for heater block, Resistor and Thermistor already. I just want a nozzle like this. Can you make just that Brian? Or does someone know where it can be purchased online in the US?
July 19, 2011 12:35PM
Hello,
I guess I misunderstood. I've got a whole bin full of the brass nozzles and can have one (or more) in the mail tomorrow.
The nozzles that I have, with the exception of the orifice, are finished. They are internally threaded to m7x1 and the first 3 threads (or so) are removed in order to accomodate any incomplete threads in the PTFE. The external threads are m6x1 and there is a shoulder to allow the heater block to seat firmly against the brass. They have a small hole, in the tip, made with a center-drill and are ready to have the orifice drilled. I can drill the orifice out to 0.25, 0.30, 0.35, 0.40, 0.50, 0.60, 0.70, 0.80, 0.90, and 1mm.
In the past, I sold them at $7.50 each.
Regards,
Brian
> [themakersworkbench.com]
July 19, 2011 07:05PM
Can you post a photo of the nozzles Brian?
July 19, 2011 08:49PM
Here are some pictures.
Regards,
Brian
Edited 1 time(s). Last edit at 07/19/2011 08:50PM by reifsnyderb.
July 19, 2011 09:20PM
Hey Brian. If you can do $7.50 each shipped to 29805 I will take 2. I will be able to paypal Thursday. I would love to try out the other hot end design but I have 10lbs of PLA and already purchased all the other hot end parts. Maybe next month I can talk myself into buying one with the heat sink from you to play around with. I guess I will do .25 and .35 for the orifice.
July 19, 2011 10:41PM
PM Sent.
July 20, 2011 03:30AM
Thanks Brian and Thanks to everyone else who replied!
I will be purchasing parts from Brian. I will be sure to post photos!
July 29, 2011 10:25AM
Brian,
I'm interested in the complete hot end kit. How much would the total be to ship to 75069?
Rickey
July 29, 2011 11:22AM
PM Sent.
crumrw Wrote:
> Brian,
> Rickey
