oz
HOW to stick ABS and nonheated table?
July 24, 2011 05:07AM
Im using rough white paper tape for printing. It does not stick well. It Needs about 265°C for abs to stick. What can i do, when i do not have heated bed?
Re: HOW to stick ABS and nonheated table?
July 24, 2011 05:28AM
People have reported that double sided carpet tape works but I have not tried that myself.
July 25, 2011 06:11PM
I found that Scotch Super 77 spray adhesive worked pretty well, when sprayed onto blue painter's tape and allowed to dry, but it did make quite a challenge of removing the print.
September 12, 2011 05:56PM
I am using regular double sided sticky tape and it work fine.
J
September 16, 2011 02:17AM
Even though it sticks to it, won't warping be an issue?
September 16, 2011 02:19AM
October 17, 2011 05:46PM
@MikeyK, if it sticks well it can't warp.
October 18, 2011 03:25PM
Just to be more specific: If it sticks well, the corners won't lift. Large prints may still warp in other ways.
November 29, 2011 05:02AM
A 10mm thick perspex print bed works very well with ABS.
You must not print PLA direcly onto the perspex bed as it bonds too well.
So for printing PLA on a perspex bed you must stick Blue painters tape onto the perspex bed first.
Bodge It [reprap.org]
BIQ Sanguinololu SD LCD board BIQ Stepcon BIQ Opto Endstop
BIQ Heater Block PCB BIQ Extruder Peek clamp replacement BIQ Huxley Seedling
BIQ Sanguinololu mounting BIQ standalone Sanguinololu or Ramps mounting Print It Stick It Cut it
My rep strap: [repstrapbertha.blogspot.com]
Buy the bits from B&Q pipestrap [diyrepstrap.blogspot.com]
How to Build a Darwin without any Rep Rap Parts [repstrapdarwin.blogspot.com]
Web Site [www.takeaway3dtech.com]
January 15, 2012 12:33PM
Thing is, my ABS seems to bond TOO WELL as well on perspex/PMMA. Can't unstick the little ABS drops !
-> is there a solvent for ABS and not for PMMA ?
February 15, 2012 06:23PM
Has anyone tried perspex/plexiglass with a HBP?
Trying to decide whether to go with a HBP/glass/perspex or HBP/glass/Kapton tape print surface for ABS
I've had spectacular results with HBP/glass with PLA.
