A smaller and lighter J-Head Nozzle smoking smiley
Posted by reifsnyderb
August 28, 2011 02:07PM
I purchased a few 6.8 ohm resistors to see if I could reduce the size of the J-Head nozzle heater block any further. I managed to reduce the heater block foot print to 13mm x 13mm (1/2" x 1/2"). While I was at it, I added some 0-80 set screws in order to secure the heater resistor and thermistor. The set screws are stacked in the holes in order to lock them in place.
This prototype weighs 3.1 grams, without the heater resistor, set screws, and thermistor. If a fluted nozzle holder is used, this may make it possible to make an entire hot-end that weighs around 14 grams.
The tip, of the nozzle, needs a little improvement as I need to grind a custom tool to make the smaller tips. But, my real goal was to see if everything could be fit into such a small foot-print. So, I am not concerned about that at this time.
I hope to be sending this prototype out for testing within the next 2 weeks. Since I just sent out my fluted nozzle holder, for testing, I'll have to make another one as it wouldn't be right to have such a small, light, nozzle without a light nozzle holder.
Regards,
Brian
Edited 1 time(s). Last edit at 08/28/2011 04:33PM by reifsnyderb.
open | download - jhn_68_prototype.JPG (119.1 KB)
Re: A smaller and lighter J-Head Nozzle smoking smiley
August 29, 2011 01:33PM
You do not want to secure the resistor with a set screw. The enamel coating can easily be deformed/damaged at higher temperatures by the set screw and short out the resistor. Some high temperature furnace gasket cement around the resistor works well to keep it in place, as an alternative. Also makes for better thermal coupling.
August 29, 2011 03:20PM
Thanks for the heads-up.
The set screw really isn't that tight against the resistor and is kept tight by another set-screw in behind it. But, you do have a really good point regarding the possibility of damage and shorting out. (I didn't think of that.) Maybe a piece of aluminum foil should be placed between the set-screw and the resistor?
Either way, furnace gasket cement, aluminum foil, etc., will need to be added to improve the thermal coupling. Even though the hole is pretty tight, you can still hold it up to the light and see the gap....which is a problem.
Maybe the thermistor set-screws would be more useful than the resistor set-screws?
Regards,
Brian
> coupling.
August 29, 2011 11:14PM
What is a normal temp range? I'm using a J-Head and I simply pushed the resistor into the hole. The fit was very snug and some material was actually shaved off. Right now I'm seeing fluctuations between +-5deg as I print.
S
August 30, 2011 12:38AM
Hello,
I'll try to find out for you and post it here.
I may be able to tighten up the fit on this as well. The reason it is a little lose on this nozzle may be due to the drill bits. I have a really cheap set of fraction, letter, and number drills that I use for making a prototype. They don't hold their edge very well and are not all that accurate.
The nozzle you have was made with a more expensive and higher-quality drill bit. So, it should have a better fit. I don't use the cheap drill bits for production runs as they are not reliable and don't stay sharp.
Regards,
Brian
> S
August 30, 2011 07:29AM
Hello,
The second test nozzle varied 2-3 degrees, according to the software.
Regards,
Brian
> S
