I have just built the Universal Mini Extruder and what with it being my first printer I am not sure what is my fault and what is the design.
I used a 6R8 resistor at 12V and it is getting up to temperature but only just, the heater is powered all the time, all be it with a bit of PWM when I am over 230C. I am trying to extrude ABS and it comes out but is not so liquid as I see it in some of the videos. Also the filament needs a bit of help in being pushed down sometimes. I suspect the hobbing on the bolt might not be sharp enough. It feeds fine with no hot end in but slips when I try and extrude. As the temperature increases I can hear some poping and occasional bubbles in the extruded plastic. Finally when I try and extrude it goes for a bit then stops. I am thinking there might not be enough thermal mass / energy to keep melting the filament as it goes through.
So:-
1) Can this extruder handle ABS or is it only for PLA?
2) How can I improve the bolt hobbing or give it more grip.
Thanks.
