Milled transparent extruder September 17, 2011 07:39PM |
Re: Milled transparent extruder September 17, 2011 09:09PM |
I'd be interested to know if you ever get excessive gear wear on the plastic gear because of the metal driver. What hot end are you thinking of? I'd definitely recommend power resistors compared to nichrome, my insanely-bodged extruder made from ceramic resistors and offcuts of wire has printed for >50 hours with no problems, while I've gone through 3 nichrome designs that have just infuriated me:|
Re: Milled transparent extruder September 17, 2011 11:06PM |
Re: Milled transparent extruder September 18, 2011 06:23AM |
Re: Milled transparent extruder September 18, 2011 09:02AM |
Re: Milled transparent extruder September 19, 2011 03:51AM |
Re: Milled transparent extruder September 19, 2011 06:13PM |
Re: Milled transparent extruder September 29, 2011 07:18PM |
Re: Milled transparent extruder September 30, 2011 08:42AM |
Re: Milled transparent extruder September 30, 2011 04:11PM |
Re: Milled transparent extruder November 14, 2011 12:11PM |
Re: Milled transparent extruder December 07, 2011 05:17PM |
I wouldn't have tackled a shaft as long as you manged to drill through though! I eventually found the best approach to drilling stainless was lots of pressure and low speed, no lubricant. Just get the drill to bite in and keep the pressure on as it peeled away.|
Re: Milled transparent extruder December 10, 2011 08:22AM |
