New to extruders and wondering about results.. October 03, 2011 01:02PM |
Re: New to extruders and wondering about results.. October 03, 2011 02:07PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: New to extruders and wondering about results.. October 04, 2011 07:29AM |
Re: New to extruders and wondering about results.. October 04, 2011 05:50PM |
Re: New to extruders and wondering about results.. October 05, 2011 05:10PM |
LEGO brick are made out of ABS (acrylonitrile butadiene styrene), it is heated to 450 degrees Fahrenheit (232 C), then injected into a mold which is kept at 85 degrees. The pressure used to mold the bricks varies from 24 to 150 tons. The molds are kept within one degree of the 85 degree specification. ABS absorbs moisture, so the entire molding hall is kept at 50% humidity. The allowable tolerance for a brick is two-hundredths of a millimeter, or about eight ten-thousands of an inch.
nophead
It does take several kilograms of force to extrude ABS and it never becomes a true liquid.
Re: New to extruders and wondering about results.. October 06, 2011 02:45AM |
Admin Registered: 15 years ago Posts: 2,569 |
Re: New to extruders and wondering about results.. October 06, 2011 05:44AM |
I always imagined that materials had to become liquid to coalesce and bond together, is this not the case?
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: New to extruders and wondering about results.. October 06, 2011 12:48PM |
