convert STL to volumetric format
October 27, 2011 04:49AM
Does anyone know any tools that actually work to convert an euclidic STL mesh
into Step/ProE/.... any of the major volumetric CAD formats?
* homeprototype free 3d design repository
* Blog
* Google+
Re: convert STL to volumetric format
October 27, 2011 07:00AM
SolidWorks can import STLs into "real" surfaces (not the default setting). Then, you can export that to STEP. Your model explodes in size, of course, because every triangle becomes a full fledged surface with a flat, triangular shape.
The STL file format isn't meant to hold editable volumes. That's why trying to edit STLs is always sort of a kludge.
October 27, 2011 07:07AM
That doesn't help one bit as I'm not interested in
a lot of flat surfaces floating in space as shells of
0 thickness but in volumes that I can edit.
(e.g. Draw sketched onto it's surface and extrude
them as a cut into the object.)
I have tried a few programs that supposedly are
able to analyse a water-tights STL model to identify
the shells, lumbs, surfaces, ... to create a volue
but none worked for anything more complex then
a cube.
* Blog
* Google+
VDX
October 27, 2011 07:40AM
... I'm mostly importing STL's in Lightwave or IsyCAM and editing the size or points or for complex operations with boolish operations to cut or combine other 3D-shapes.
But the representing objects stay defined per point-cloud, surface and normals, so this is no real conversion.
For changing them into 'real' 3D-objects, i have to reconstruct with CAD-primitives and bool, what's sometimes no problem by matching the constraints to the already existing points ...
Viktor
November 03, 2011 06:06AM
Turbocad and Viacad both do the conversion, but of course they can't reconstruct curved surfaces from facets.. The difference between them is that Turbocad consolidates coplanar, contiguous facets into a single face. Viacad doesn't, but both perform booleans et al and give the same output once the conversion's been done.
