I've read that when you do an F5 compile, difference() will show green objects that are being removed. For some reason openscad only does this sometimes. Most of the time, when I hit F5 everything is removed like it should and I am left with only the modified object left, which is great. Unfortuneatly as my design increases in complexity I now only get giant green objects when I hit F5 and am forced to wait a few minutes every time I make a change so that an F6 compile and render can complete. Any ideas what's going on?
Thanks
edit: apparently it was an issue with the preview mode of openscad. I fixed it by adding this before the seciton that created the problem part:
render(convexity = 2)
Edited 1 time(s). Last edit at 04/20/2011 02:54PM by inh.
