I want to write a scad module to take the child/ren and manipulate them, but I need to know something about them, in this case the dimension on one of the axis so I can use an 'if' to do different things.
Specifically the module is to take an object cut it in half (or rather make two objects with different intersection/difference spaced apart) and rotated so the cut face is down. Thus allowing an irregular object to be 3D Printed.
The objects are all, but one, to be sliced at a given plane, but the other needs a different plane, it can be distinguished by its Y axis size is larger.
Is there any way to access child() attributes?
Yes I could do two modules, but where's the fun/learning?
Michael
