Can someone please help, I'm remodeling an item, I build the item for the most parts, I need to make 6 holes to an object, the object was turned to a component, as well as each of the cylinders that need to be subtracted from the object, while 3 of the cylinders were subtracted without any problems 3 wont get subtracted.
Attached is the file which is almost self-explanatory
Thank you
