*solved* A Blender made 125 tooth pulley won't be sliced correctly December 03, 2012 05:03PM |
Slicing D:\reprap\pulley\pulley125b.stl Slicing: Slic3r/slic3r.exe $s --load Slic3r/config.ini --output $o => Processing input file D:\reprap\pulley\pulley125b.stl => Processing triangulated mesh The model has overlapping or self-intersecting facets. I tried to repair it, however you might want to check the results or repair the input file and retry. => Generating perimeters => Detecting solid surfaces => Preparing infill surfaces => Cleaning up => Detect bridges => Cleaning up the perimeters => Generating horizontal shells => Combining infill => Infilling layers => Generating skirt => Exporting GCODE to D:\reprap\pulley\pulley125b_export.gcode Done. Process took 1 minutes and 51.406 seconds Filament required: 49248.1mm (348.1cm3) 49247.13568 mm of filament used in this print the print goes from 12.739000 mm to 227.379000 mm in X and is 214.640000 mm wide the print goes from 12.604000 mm to 227.384000 mm in Y and is 214.780000 mm wide the print goes from 0.400000 mm to 22.000000 mm in Z and is 21.600000 mm high Estimated duration (pessimistic): 55 layers, 09:10:15
Re: A Blender made 125 tooth pulley won't be sliced correctly December 03, 2012 06:30PM |
Slicing D:\reprap\pulley\pulley112.stl Slicing: Slic3r/slic3r.exe $s --load Slic3r/config.ini --output $o => Processing input file D:\reprap\pulley\pulley112.stl => Processing triangulated mesh => Generating perimeters => Detecting solid surfaces => Preparing infill surfaces => Cleaning up => Detect bridges => Cleaning up the perimeters => Generating horizontal shells => Combining infill => Infilling layers => Generating skirt => Exporting GCODE to D:\reprap\pulley\pulley112_export.gcode Done. Process took 5 minutes and 21.547 seconds Filament required: 11125.1mm (78.6cm3) 11124.07823 mm of filament used in this print the print goes from 22.780000 mm to 217.210000 mm in X and is 194.430000 mm wide the print goes from 22.782000 mm to 217.212000 mm in Y and is 194.430000 mm wide the print goes from 0.400000 mm to 22.000000 mm in Z and is 21.600000 mm high Estimated duration (pessimistic): 55 layers, 03:49:08
solved :-) December 03, 2012 06:57PM |
Re: *solved* A Blender made 125 tooth pulley won't be sliced correctly December 11, 2012 03:17PM |
Re: *solved* A Blender made 125 tooth pulley won't be sliced correctly January 22, 2013 05:54AM |
