Rendering an imported object in OpenScad
Posted by Replace
January 19, 2013 08:48AM
Hi all,
I seem not to be able to modify other people's .STL files in OpenScad
When I import ( or stl-import, no differences) an STL file and I add some structures in which I diffence some text, the compile [F5] will show as expected, however,
The rendering [F6] will remove the imported object, leaving only my added code.
And as expected afterwards, the new exported STL also lacks the imported object :-(
As said, no matter which import statement I use.
Any clue's
Advice appreciated
Thomas
Edited 1 time(s). Last edit at 01/19/2013 08:57AM by Replace.
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Rendering an imported object in OpenScad
January 19, 2013 09:43AM
This happens when the stl you're trying to import is broken in some way. Run it through cloud.netfabb.com and it'll work. Openscad is really fussy when it comes to importing stls.
January 20, 2013 08:18AM
Great advice!!
Afterer the netfabb fix, I could merge and render the new object.
Many thanks
Thomas
