Extrude 2D shape along a path
May 14, 2013 04:46AM
Hello,
I'd like to extrude a 2D shape along a path to make the following 3D shape:
Bridge with curved ends
Does anyone know if it's possible to do that in OpenSCAD? Or if not then is there alternative free 3D software that will do the same thing (extruding along an arbitrary path)?
The reason I want to make it by extruding is that the way I've done it at the moment is really ugly and does not work properly so I have to bodge it. Extruding will make it simpler.
Will
Re: Extrude 2D shape along a path
May 14, 2013 06:14AM
Most 3d modeling programs should be able to do that. They call it sweep or loft. Autodesk'sInventor and 123d Design can do it
May 14, 2013 11:17AM
It's called a sweep. A loft is blending between multiple 2D sketches (like an air duct transitioning from a rectangular cross-section to a circular cross-section).
May 14, 2013 11:42AM
> Will
FreeCAD [www.freecadweb.org]
If you need help with the learning curve http://sourceforge.net/apps/phpbb/free-cad/viewforum.php?f=3&sid=d306e44b6d89c4a52d76d51a116b730c
From memory you create your 2d path in sketcher workbench. Create your path as a wire and then use sweep in the Part workbench. Its been covered in the forum in the past.
Edited 1 time(s). Last edit at 05/14/2013 11:52AM by KeithSloan.
May 29, 2013 05:52AM
openscad can extrude a dxf into a 3d object?
Ben
May 29, 2013 10:30PM
In the topic you created for the other way around (STL to DXF), rhmorrison gave you a link to the OpenSCAD wiki. The extrude option is right there under the "3D to 2D Projection" chapter.
May 30, 2013 06:19AM
NormandC if you're replying to my answer this isn't my topic I was giving the OP a suggestion.
Ben
May 30, 2013 05:55PM
You ended your sentence with a question mark, so I assumed it was a question and answered it...
Edited 2 time(s). Last edit at 05/30/2013 05:58PM by NormandC.
