Problem with 3S text in sketchup and Cura
Posted by Antslake
February 06, 2014 11:36PM
For the life of me I can't figure this out. I am designing a simple cap, on the top of the cap I want there to be an engraving of letters, so in sketchup I use the 3D text tool and make it. When I place the object in Cura, either face up or face down, the letters either disappear, or just the top of the cap disappears, and the letters remain. If I place the object on it's side, everything is there.
I am checking it in layer view so I can see what the printer will actually print. I tried putting the object into netfab and repair, same thing. Help! thanks grinning smiley
Re: Problem with 3S text in sketchup and Cura
February 07, 2014 09:13AM
Sketchup is known to produce bad STLs that confuse slicers (not tried myself, just read often about it).
Maybe try another Design tool.
A2
February 07, 2014 10:04AM
DeuxVis, is correct, I have a friend that uses it.
It's not recommended to use a surfacing modeler to create STL data files.
There is a much higher probability for holes in your model, which are some times difficult, and time consuming to fix.
Best to use a solid modeler, (e.g. FreeCad).
[freecadweb.org]
[sourceforge.net]
[forum.freecadweb.org]
February 07, 2014 11:20PM
I am finding that out. It seems everytime I try to design something I run into a wall with sketchup. Looks like I am going to have a learning curve in front of me again, took me long enough to get good at sketchup. I have blender, is that just as good? What's a good line on tutorials? They seem scattered to me. I want to go in order and assume I know nothing.
A2
February 08, 2014 02:35AM
Don't use surfacing software.
If you were happy with Sketchup then use a solid modeler.
