Inkscape 2D to sketchup 3D ???
Posted by BobHewson
March 23, 2014 05:07PM
I have a drawing in both SVG and DFX formats, originally designed for laser cuting with 3mm plywood. I'd like to do the project with my 3D printer.
I first tried cleaning up the SVG drawing in Inkscape (I needed to make shape outlines continuous) and separated the parts as stand-alones. Sketchup wouldn't import the files.
Next I tried opening the DXF file directly in Sketchup 2014, successfully, and joined all gaps. I thought it would then be a simple matter of using the Sketchup Push/Pull feature to thicken the parts to 3 mm (same as the plywood thickness used with the laser cut project).
No so, I was unable to utilize this feature in Sketchup.
Would anyone have any suggestions of how to do what I am attempting?
Thanks,
Bob
(unable to share file as it is proprietory)
Edited 1 time(s). Last edit at 03/24/2014 12:07PM by BobHewson.
VDX
Re: Inkscape 2D to sketchup 3D ???
March 23, 2014 06:06PM
... I'm sometimes re-converting SVG's and DXF-files with OpenOffice-Draw, Corel10 or other programs -- so it's then compatible to the import-plugins of my CAM's.
This is sometimes a sort of testing/exchanging between the different format versions (especially in DXF) to find the correct one eye rolling smiley
Viktor
March 23, 2014 09:41PM
Bob,
Just a thought, if you can share the link to the original DXF and SVG files, other could have a look at them.
I personally don't use Sketchup but would be willing to give it a shot in FreeCAD.
