Using one object to cut a hole in another!
Posted by GRAYWOLF
January 27, 2015 02:59PM
I use inventor fusion to create my master models then import into 123d for finale tweeks (can't get the same control in 123d hence the odd way to do things)
I have a part finished and I have started on the second piece but I have a confusion (still learning cad work.) Can I use Part 1 to cut a hole into Part 2?
Re: Using one object to cut a hole in another!
March 27, 2015 12:17PM
Can do it with Blender smiling smiley
[youtu.be]
October 01, 2015 06:24AM
Here i have a link that will solve your problem definitely...
http://www.wikihow.com/Cut-a-Hole-in-an-Object-in-Adobe-Illustrator
October 04, 2015 10:48PM
I use OnShape.com rather than Inventor Fusion or 123D, but this is a fairly typical operation for CAD, so I'd expect any decent CAD system to support it.
Try a Boolean operation to difference one object from another.
In OnShape, there's also an operation to take one object and split it into two, along some arbitrary surface.
January 17, 2016 08:43PM
The OpenSCAD "difference" function is exactly this.
January 30, 2016 10:19AM
Use SketchUp free or Pro. Intersect faces or Boolean operations. Use x10 or x100 scale to avoid problems. Not always 100% solid, but easy to use. Diggolike, Adobe illustrator? Not for 3D I think?
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
