[SOLVED] How do I split .stl files in 123D Design?
Posted by GRAYWOLF
February 01, 2015 05:12AM
As google seam to be dislexic or controlled by Skynet How do I split an object using 123d Design on OS X?
Edited 1 time(s). Last edit at 02/01/2015 03:22PM by GRAYWOLF.
Re: How do I split .stl files in 123D Design?
February 01, 2015 06:33AM
eye rolling smiley Practice: Split Solid
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
February 01, 2015 06:41AM
Nope, doesn't work, doesn't allow me to select the object
Re: [SOLVED] How do I split .stl files in 123D Design?
February 01, 2015 03:23PM
Strange way to do things but at least it now works!
March 16, 2015 06:58PM
Graywolf, what ended up working? I bet I've spent five or six hours on this one issue. When I try to split an object, I can't select the target object.
March 25, 2015 02:59AM
This is how I got it to work
1, load object,
2, draw cube around section to remove,
3, goto Cobine>Subtract,
3.5, Select Object in the pill shaped dialogue
4, select object to be cut,
5, select cutting object,
6, hit return.
The OS X version of the programs are very broken.
Sorry, been very busy and kept getting the same bug that you did
March 27, 2015 12:48AM
i use NetFabb basic to split objects. Much faster and easier.
December 06, 2015 12:38PM
An .stl file in 123d design is a mesh. You have to convert it to a solid first before splitting it. Click on the ENTIRE .stl file and the 'gear' comes up. Select 'convert mesh to solid'. The only problem is that if it is a very complex shape, it may have more segments than 123d design or your computer can handle. I've had mixed success.
