Autodesk 123D free maker design program. May 24, 2011 06:50PM |
Re: Autodesk 123D free maker design program. May 25, 2011 06:05AM |
First impression: * terms and conditions exist in 4 dozen languages but German is missing * program is a Beta * program only exists in US-english * all the points in "Learn About 123D" do not work on a 64bit Windows (they try to open an swf as a file and the Adobe web-site says that the flash player 10.x is no available in 64 bit.) * lines in sketches are hidden in "draw" * sketches can be on flat surfaces but not on non-flat ones * If the model is in metric units, you cannot specify inches for features (e.g. a 1/4 hole to attach a camera in a metric part) * the only constraint I have found is "pin down" = lock feature * I cannot find the operations I did in the model-hierarchy or any kind of construction-timeline * I also cannot find a way to temporarily supress and operation, only parts * I can enter basic formulas but not variable-names It seems to be some kind of "Sketchup meets ProE". Give extremely visual oriented people very basic parametric tools without allowing much in terms of later modification of the created object. Useful for simple modifications to solid models in the usual CAD- formats and simple 1-off parts. Not so much for complex parts that you test-print and then modify earlier steps in the construction history or change any parameters at all. Marcus
Re: Autodesk 123D free maker design program. May 26, 2011 12:41AM |
Re: Autodesk 123D free maker design program. May 26, 2011 12:54AM |
Re: Autodesk 123D free maker design program. May 30, 2011 10:14AM |
cva
Re: Autodesk 123D free maker design program. May 31, 2011 06:07AM |
Re: Autodesk 123D free maker design program. May 31, 2011 01:29PM |
Autodesk 123D beta update July 06, 2011 01:49AM |
Re: Autodesk 123D beta update July 06, 2011 01:50AM |
Re: Autodesk 123D free maker design program. October 03, 2011 06:27PM |
3dFan
Re: Autodesk 123D free maker design program. May 30, 2012 01:06PM |
Re: Autodesk 123D free maker design program. May 31, 2012 07:41AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Autodesk 123D free maker design program. June 21, 2012 10:45PM |
Admin Registered: 16 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Autodesk 123D free maker design program. June 23, 2012 06:34AM |
