Gear milling machine
January 11, 2012 12:01PM
I'm thinking something like an eggbot with a dremel. it would need control of the drill head height and lateral position, and a stepper for the gear rotation.
This would be a nice little project to put together after building a reprap, since you could use your steppers and electronics to control the axes.
Re: Gear milling machine
January 11, 2012 01:22PM
I've attached a very quick mockup. The orange part is the dremel, the yellow is the printed frame, the blue is the gear blank, and the green is printed racks
open | download - gear mill.png (48.4 KB)
January 11, 2012 03:35PM
I think you can hob simple gears with just a rotational axis plus a a rotary cutting tool mounted on a linear axis. the third axis is a plus, but optional.
Sort of like this:
www.youtube.com/watch?v=ELCU52OnGbg
so one could imagine a simpler rig...
January 11, 2012 03:54PM
No Ii think you'd still need a second planar axis to control tooth depth. And a dremel cutting bit, instead of the cutoff disks, would allow you to cut helical or herringbone gears
