Good examples?
Posted by DaveR
Re: Good examples?
March 14, 2009 03:05PM
Really, could that be a way of powdering it for recycling?
Edited 1 time(s). Last edit at 03/15/2009 04:26AM by nophead.
Lethosos
Re: Good examples?
March 16, 2009 05:14PM
But only if you remove the moisture generated by condension that will invariably form at any temp above 0 degrees. Particles behave funny with liquids, and the recycling process could be effected by moisture.
Still, with a little bit of kiln-drying (or similar,) that won't be an issue--you'd just have to first do some general pulverizing while it's still frozen before drying.
Re: Good examples?
August 31, 2009 11:14PM
>>Hi all.
>>I've been lurking for a bit, and RepRap sounds like a really interesting project. >>However, before I jump in with both feet, I'd like to ask for some >>opinions/advice.
>>To assist with the WAF (Wife Acceptance Factor), and to shift towards a symbiotic
get some gold spray paint, and make jewelry, or stupid over-designed shoes & handbags,
[in between what its really for, prototype robot armies etc]
Edited 1 time(s). Last edit at 08/31/2009 11:16PM by ceti331.
Re: Good examples?
September 09, 2009 08:03AM
degroof Wrote:
> gmsieling Wrote:
> > I'm hoping to be able to make those
> > easier by printing an extrusion of a pattern
> with
> > some backing. Rubber stamps can be expensive
> > ($5-$20/each) so I think if I can get it to
> work
> > it would appeal to scrapbookers.
> Yeah, I can see these being relatively easy to
> make. I guess the material would need to be fairly
> flexible. Maybe something like silicone sealant
> would do.
Print your stamp, glue some rubber over it and push hard over the top to make indents in the rubber and then cut out the holes with a knife. Now you have a firm base plus a soft rubber coating,, should be a perfect stamp. Alternatively print the stamp directly on to the rubber and follow the above.
PS, haven't even started my reprap so the above might be rubbish but it will be the first thing I try.
Re: Good examples?
January 19, 2012 06:54PM
DaveR Wrote:
> Currently, the stated primary focus of the RepRap
> project is to reproduce itself. This is a great
> goal and very cool. However, if this is achieved,
> it will initially be a parasite. Preying on the
> time, money and effort of supporters, it will
> quickly reproduce itself until it has consumed
> every available host, evolving as it goes.
Hi DaveR,
even if the RepRap would only replicate itself,
it is a great learning process to get into the topic, to achieve skills (to be able), to build one (creativity).
If the skills to build one are spread, the technology - the RepRap - can be distributed and evolve - and more
people can tinker with it, come up with ideas and use cases.
Someone who can build a RepRap is empowered - because of the openness -
to adapt the technology and provide a solution for a unique problem.
The great effect I observed is, having a RepRap comes with a desire
to be able to construct data which can be 3d printed. Another self-driven learning process -
which is empowering the individual.
The wide spread access to (advanced) open source technology and knowledge is a guarantor,
that at some point in the future, RepRap - the idea behind it, will find a fertile ground for the broader benefit of mankind.
Meanwhile it is still legitimate to just support and spread the idea of 'Open Source Hardware', 'Open design' by
helping your friends and colleagues to get a RepRap too.
Marcus
01577 42 20000
[www.manupool.de]
Re: Good examples?
January 28, 2012 12:54PM
Umknowmthos was a 3 year old post?
