More than extruding filament: PRINTING FILAMENT !
Posted by corngolem
August 22, 2013 04:01PM
It means that you design a stick or a roll and your print it with your 3D printer ! and then you use the filament you just printed to print something ! ... such as the filament you just used ! hahahaha POOOOOOOOM
Crazy idea, I just had to share it.
The only use I see is to make filament of another diameter, but of course it's simpler and faster to use an appropriated nozzle for that.
Re: More than extruding filament: PRINTING FILAMENT !
January 21, 2014 01:33PM
You're not the only one who has thought of this crazy but mostly useless idea. It would be interesting to see how many times you could reprint the filament before it degrades too much.
February 06, 2014 05:19AM
If you print it on a conveyor belt or any other print auto-removing platform, you could even form a loop with the printed filament feeding back directly into the extruder.
A new kind of useless machine smiling smiley
