3d Print a water cooling system for a hotend
September 03, 2013 08:06PM
I've seen the water cooled hotend before but the cooling block requires machining and must be made out of metal, my first idea was a block thst went on the outside of the peek that was fully 3d printed however I was worried about heat transfer, what i came up with is a cooling block that goes around the PEEK but there is a open hole for the PEEK so the water is touching it , then use RTV to seal it up. Thoughts? I have a steve's hotend so my hotend and peek is alittle bigger then some.
Re: 3d Print a water cooling system for a hotend
September 04, 2013 07:28AM
Here is my water cooled hot end. [reprap.org]
Edited 1 time(s). Last edit at 09/04/2013 07:30AM by Greg Frost.
What do you do about cooling the water, do you use some form of radiator or just
a large tank ?
September 06, 2013 08:32AM
I have what must be about a 2 liter container. That is plenty big enough to cool itself.
October 06, 2013 09:22PM
lol reviving this, i am going to give this a shot designing it if i can, Latley i have been having problems with my printer but its all good now
November 22, 2013 11:58PM
I recommend using the search function, type in your topic title, "Recycling PLA and ABS" and click search.
There are a lot of discussions on this, and you can also search this topic on youtube to see DIY Grinders and Filament Extruders.
I am happy that I got the best working done for the JN0-660 for more info visit ECCOUNCIL for further visit us Amazon for more info check this out on Infosys for now open it at Youtube good luck
