Idea for increasing build volume of delta style printers in z direction March 19, 2014 06:31PM |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 12:10AM |
Admin Registered: 15 years ago Posts: 730 |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 12:33AM |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 12:53AM |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 01:39AM |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 10:32AM |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 01:40PM |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 04:57PM |
Re: Idea for increasing build volume of delta style printers in z direction March 21, 2014 05:18PM |
naxem42
Maybe you can use less steppers if you move the platform like how Nicholas was saying?
nicholas.seward
*You would need 3 steppers for the XY motion to avoid bad singularities in the middle of the work volume.
However, this is over-constrained and would be hard to control without the steppers fighting each other.
Re: Idea for increasing build volume of delta style printers in z direction March 22, 2014 01:29PM |
I know Nicholas is the expert hereQuote
nicholas.seward
*You would need 3 steppers for the XY motion to avoid bad singularities in the middle of the work volume. However, this is over-constrained and would be hard to control without the steppers fighting each other.
but I think that the cable drive on this one makes it kind of a weird beast. In naxem42's original design, the platform is also free to rotate about the Z axis - but it finds a unique minimum. (Maybe this is what Nicholas means by singularities - that the platform is inherently not stiff to disturbances in Z rotation. But if the extruder is in the middle of the platform we don't mind so much about this.)
Re: Idea for increasing build volume of delta style printers in z direction March 22, 2014 02:25PM |
Re: Idea for increasing build volume of delta style printers in z direction March 25, 2014 09:23PM |
