no-warp construction techniques April 26, 2010 04:51AM |
I´m currently printing this frame-vertex: [www.thingiverse.com]
With the settings I´m deliberately using there should be serious warping. However,
there is practically none.
With the V-shaped cuts in the bottom these are 3 separate objects during the important first few layers
that keep each other down. (Much like the special throw-away objects discussed here a while ago to keep the raft on the edges of a large object weighted down.)
There is no part long enough to form a lever and the levers that do form work both ways and reduce
the warping that is left to half the amplitude.
When the parts merge higher up there is already so much mass printed that it keeps the object down without effort.
I guess we have found a way to print large objects in ABS without requiring a heated bed for it!
And all it requires is a change in the shape of the object.
(My frame-vertex is also hollow but that does nothing to prevent warping in the first 5-10 layers. It just saves material and time.)
Re: no-warp construction techniques April 26, 2010 03:43PM |
Re: no-warp construction techniques April 26, 2010 03:49PM |
Re: no-warp construction techniques April 29, 2010 05:22PM |
Re: no-warp construction techniques April 29, 2010 05:32PM |
Re: no-warp construction techniques April 29, 2010 05:36PM |
Re: no-warp construction techniques April 29, 2010 05:50PM |
Re: no-warp construction techniques April 29, 2010 06:02PM |
Unless I'm wrong and they are posting their source files, but a quick look around their home page turned up nothing.|
Re: no-warp construction techniques April 29, 2010 06:15PM |
very new warp free 3mm filament available/ wow July 23, 2010 09:03AM |
