DLT-350 Print size(X,Y,Z): 280×280×350mm
DLT-600 Print size(X,Y,Z): 280×280×600mm
He3d-DLT-350 Delta 3D Printer Kithot
Technical parameters:
1.Integrated SD card with LCD monitor display.
2.The Layer Thickness: 0.05-0.4mm
3.Layer Resolution: 50 microns
4.Printing Filament: PLA & ABS. Heatbed Required for ABS.
5.Technology: Fused Deposition Molding (FDM).
6.Construction based on parallel arm (delta).
7.Machine dimensions: height:870 mm width:430 mm length:430 mm , the total weight: 12 kg (including packaging)
8.Outer frame: imported aluminum, steel (laser precision cutting)
9.Extruder:remotely and high-speed extrusion machine
10.The print head material: copper, aluminum, polyether ether ketone material forming
11.Nozzle diameter: 0.4 mm (18, J - head hotend)
12.Filament diameter: 1.75mm
13.Nozzle number: single nozzle
14.Data format: STL
15.Software: Repetier host
16.Print size(X,Y,Z): 280×280×350mm
17.Plate size:d=310mm
18.Power input: AC110-220 - v
19.The power supply output: DC 12 v 7 a
20.Print plate: high borosilicate glass 180 mm in diameter
21.Synchronous belt wheel / 16 teeth, belt GT2
22.Upgradable to heatbed.
The performance parameters:
Print Speed: 100 mm/s
Print thickness of 0.05 mm to 4 mm
Mechanical precision is 0.0125mm
The operating system, Windows/Mac/Linux
High-speed USB device interface or SD card
The complete printer pack includes :
3d DLT - 180 delta printer (fully assembled)
The power supply (12 v 7 a) - 1 set
USB cable - 1 set
100 grams of filament to print test material
1
