Mobius Solids in OpenScad
Posted by Buback
March 11, 2011 11:03AM
I'd like to be able to create mobius solids on my printer. Solids are just mobius strips that have some thickness. it'd be nice to have the option to tell it how many folds it has.
probably a pretty tricky script. i don't even know where to begin :-(
Re: Mobius Solids in OpenScad
March 11, 2011 12:55PM
Take a look at the scad file here for an idea of where to start:
[www.thingiverse.com]
You'll want to use a couple nested for loops with rotations to get the desired effect.
Cameron
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
March 11, 2011 01:13PM
Möbius strips aren't allowed in the STL file format ...
March 11, 2011 01:15PM
> format ...
Can't a solid mobius strip be designed with just one outer surface? In OpenSCAD it wouldn't be a true mobius strip since you would have to rotate boxes to form the strip, but I can't see why it wouldn't work.
Cameron
March 11, 2011 01:22PM
really? I thought an stl was just a bunch of layered images, in effect, like a cat scan.
I guess a mobius strip is technically/mathematically a 2d structure, but in actuality a printed one would have height.
> where to start:
yeah that's what got me thinking about it. i'd like to get a shape like the one on page 7 of the attached PDF.
open | download - IMAGINARY-Moebiusband-Stephan-Klaus.pdf (566.8 KB)
March 11, 2011 01:56PM
An .stl file represents a solid as a mesh of flat triangular faces. Layered images would be some kind of voxel format. Since the .stl is composed of triangles, there is no "single outer surface" for a Möbius strip, and no single boundary edge. As with everything else, the .stl can hold only a faceted approximation Möbius strip. It's no less able to do this than represent a sphere.
March 11, 2011 03:03PM
ah ok. just read up on .stls.
It's the normal vector if each that's the issue. I don't think it's an issue with a mobius solid, since there will be an 'inside' and 'outside'
January 24, 2014 07:20PM
Yes they are...the web is full of examples. STL and even openscad.
A few examples are listed below.
Ian Mott
http://www.thingiverse.com/thing:11195/#files
http://www.thingiverse.com/thing:184756/#files
http://www.yeggi.com/q/mobius/?s=tt
