V large 3d build advice February 01, 2018 09:04PM |
Re: V large 3d build advice February 07, 2018 07:02PM |
Re: V large 3d build advice February 08, 2018 11:35AM |
Re: V large 3d build advice February 08, 2018 12:15PM |
Re: V large 3d build advice February 08, 2018 01:22PM |
chromaglow
Thank you all sooooo much for the responses!!!!!!
This dialog is just what I needed. I am totally capable of researching and building a thing once I know what the known's are but here I have been completely out of my element.
I am printing PLA in thin pieces no thicker than 8mm .2/.3 mm layer height
For this reason I started out thinking I should make a cartesian printer.
Also for the base plate I figured I would do dual, belt driven nema motors.
Not sure about heat yet since I technically don't need it to stick to the base and with long print times like a month It would be nice to avoid making all that heat and using electricity if possible.
I looked at the hang printer and was all about it for 5 minutes until I saw the high mass and torsion of the print head will not allow it to be detailed enough to do what I need it to do.
Black belt looks like it could do exactly what I need but holy smokes looks very very expensive.
Re: V large 3d build advice February 08, 2018 03:41PM |
Re: V large 3d build advice February 08, 2018 03:43PM |
Re: V large 3d build advice February 08, 2018 07:08PM |
Re: V large 3d build advice February 09, 2018 06:34AM |
Re: V large 3d build advice February 09, 2018 04:13PM |
Re: V large 3d build advice February 09, 2018 06:25PM |
I'm happy to help - - always interesting to wrap your head around new problems.|
Re: V large 3d build advice February 11, 2018 02:58PM |
Re: V large 3d build advice February 11, 2018 03:27PM |
Re: V large 3d build advice February 12, 2018 01:58PM |
Re: V large 3d build advice February 12, 2018 04:56PM |
chromaglow
Related question.
If I slice files in Simplfy3d will the Reprap software on the duet read and execute it properly?
Re: V large 3d build advice February 12, 2018 05:34PM |
Re: V large 3d build advice February 13, 2018 02:22AM |
Re: V large 3d build advice March 12, 2018 04:38PM |
Re: V large 3d build advice March 13, 2018 04:24AM |
