If you are looking to start your Mendel construction, this is the kit for you!
This kit contains 1 Reprap Mendel PCB and all of the 51 components to build a Reprap Mendel. (as shown in the picture.)
I was able to put this kit together from extra parts I ordered for building my Mendel.
Buying just the components individually will cost over $27 before shipping.
Kit contains:
[Serial ] - .100 breakaway header (right-angle) (1 piece 6 pin)
[R4, R5, R6, R11, R12] - 1.8k ohm resistor 1206 (5)
[ ] - 10 pin female header (4)
[X, Y, Z, JTAG ] - 10 pin IDC header (4)
[C3, C5, C8 ] - 100nF ceramic capacitor 1206 (3)
[R1, R13, R14, R18] - 10k ohm resistor 1206 ( 4)
[C6 ] - 10uF electrolytic capacitor D55 (1)
[C1, C2] - 15pF ceramic capacitor 1206 (2)
[Q2 ] - 16Mhz crystal (1)
[ ] 2 Pin Molex Conn (Reprap mod) (5)
[R2, R3 ] - 1k ohm resistor 1206 (2)
[R7, R8, R9 ] - 3.3k ohm resistor 1206 (3)
[] 100 uF Capacitor (Reprap mod) (1)
[SD CARD] - 3M sd card socket (1)
[ ] 4 pin female header (4)
[R10, R15] - 4.7k ohm resistor 1206 (2)
[ICSP] - 6 pin IDC header (1)
[IC2 ] - Atmega644p tqfp (1)
[] 3.3v regulator 78l33 (Reprap mod) (1)
[POWER] - Green LED 1206 (1)
[Reset] - Omron B3F-1000 Button (1)
[DEBUG] - Red LED 1206 (1)
[IC1] - SN75176A SOIC (1)
[ON/OFF] - SPDT switch (1)
[PCB] - RepRap Motherboard v1.2 PCB (1)
Kit does NOT contain:
Solder paste
Hot Plate
The kit is available on ebay at:
http://cgi.ebay.com/RepRap-Motherboard-1-2-bare-PCB-/140465990979?pt=LH_DefaultDomain_0&hash=item20b46ced43
Thanks,
Tom
