To confirm pricing and availability, and for more information, contact
wildseyed@gmail.com
DIY Build Instructions for the hot end are available at the wiki, for those of you who can. I build them for those who can't.
Extruder Includes:
1 Greg's Hinged Extruder Body
1 Hinged Idler
1 Large Gear
2 Small Gears
3 608 Roller Bearings
1 Idler Shaft
1 Hobbed 5/16" Bolt
4 1/4" Washers
2 5/16" Nuts
7 6-32 Nuts
2 6-32 Long Screws
1 6-32 Short Screw
Hot End Includes:
1 1/2" PTFE Rod, 3mm I.D., Drilled and Shaped, Please specify for which machine (Prusa, Mendel, Techzone, etc.)
1 1/4" Female Air Hose Coupling
1 0.8mm Copper MIG Welder Tip, Assembled, and Shaped
1 Aluminum Block, Drilled
1 Aluminum Encased Power Resistor
1 100k Thermistor, Wrapped and Barreled to 24" Wire Leads
2 Alligator Clips and 24" Wire Leads for Resistor
Extruder and Hot End comes to you fully assembled, and adjusted for 3mm filament.
Edited 3 time(s). Last edit at 06/07/2011 12:44PM by jcabrer.
