We have made some changes to our H-1 Huxley designs, and are offering up the new kit along with upgrades for any of the over 400 kits we've already made! If you have your H-1 built already, you can go
HERE and download the new .stl files as well as blueprints for the machined parts and print your own plastic upgrades, or we are offering them as kits
Here
If you don't yet have a machine, we are currently selling the H-1 original kit on our website at [
seemecnc.com] or you can pre-order the H-1.1on
Indiegogo.com We are offering parts and hardware kits, kits for Mach3/EMC based setups, RAMPS 1.4 with kits, as well as the upgrades to existing H-1 kits.
We also now have LM8UU bearings on our website as well as teflon tubing for hot-ends and bowden tubes, Our hot-ends in both 1.75mm and 3mm sizes, .28mm (.011"), .37mm (.0145"), .5mm (.020") and .635mm (.025") nozzles, ATX Power supplies, 4 axis parallel port stepper boards for other CNC projects, RAMPS 1.4 kits, PEEK material for your experimental parts, and more!
Edited 2 time(s). Last edit at 06/06/2012 05:47PM by johnoly99.
John "Oly"
SeeMeCNC.com
