Hi all,
I now have a 3mm Aluhotend-HT
The Aluhotend-HT-3mm is designed for high temperature printing with ABS ,NYLON ,POLYCARBONATE, by default the nozzle size is 0.4mm and the hotend comes assembled and sealed ready for use, does not include a heater cartridge or thermistor, this hotend will handle PLA as well however for more reliability i recommend the "Aluhotend-LT-3mm or the Aluhotend-LT-1.75mm",
the improvments over the last versions are:
- lighter from 39 grams to 22 grams
- shorter 80mm to 58mm
- now features a ptfe liner to mitigate potential jams and regulate back pressure (LT version)
- mounting point dimensions match the jhead mount more accurately
- heater block is now shorter and the heater cartridge/resistor hole is bigger
- improved nozzle geometry with a shorter orifice for reduced back-pressure
price is $65Aud each
Available at
3dindustriesaustralia or by emailing me
thejollygrimreaper@gmail.com
