More details at [
norcalreprap.com]
Prusa Mendel I3 Single Plate ALUMINUM frame 3D Printer Kit
This is a Kit for the Prusa Mendel I3 Aluminum Frame that is 99% Complete!
You only need a Glass plate for the Heatbed, some clips to hold the glass to the bed and Filament.
This kit is the Prusa Mendel I3 Einstein variant, orange in color includes the following:
approx 20cmX20cmX20cm build area (8"X8"X8")
CNC Milled Aluminum Frame with threaded holes for easy assembly(Natural Aluminum Color)
Sanguinololu 1.3a with genuine Pololu stepper drivers. Assembled and tested by us at NorcalReprap.com You can upgrade to RAMPS 1.4 with Mega 2560 for $30.00 at the bottom
J-head hot end from Hotends.com
5 Kysan Nema 17 5.5kg/cm stepper motors
Hive76 Milled hobbed bolt (the best we've ever found)
12v 30Amp Power Supply with Power cord
Mk1 Heatbed
10MM & 8mm Threaded rods
Lm8uu Bearings for smooth linear movement
GT2 Belts & 10Tooth GT2 pulleys
More details at [
norcalreprap.com]
use coupon code a9e2fd2399 at checkout and receive 10% off your purchase of 100$ or more. Coupon exires 8/19
Edited 2 time(s). Last edit at 08/12/2013 09:57PM by wpafan.
