Hello dear friends, it's Grace from Siridi 3D Printing Supplies. We manufactures 1.75mm 3mm ABS Filament and PLA Filament with 21 colors.
Our filament advantages:
(1) high strength, good toughness;
(2)density is small, when printing larger volume model lighter, save money;
(3) cost-effective, can be processed in wide range temperatures;
(4) Good human biocompatibility, avirulent and harmless
(5) diameter of 3.0/1.75mm, variations + /-0.1mm,roundness +/-0.05mm;
(6) Good biodegradation, suitable for family compost degradation
(7) to be applied to a variety of 3D printers, Makerbot, Mendel, Prusa, Huxley, WeisTek, Thing-o-matic, Ult, BFB series, etc
Specifications
POLYMER PROPERTIES ABS COLORED
Print temperature 220-260 ºC
Raft required Optional
Filament diameter 3mm/1.75mm
Spool N.W 1kg
Packaging Detail: 1kg/spool/polybag/box, N.W.:1kg, G.W.:1.4kg box size: 22*21.5*8.5cm 12box/carton, N.W.: 12kgs, G.W.: 16kgs carton size: 54*44*23cm
Production Control
1. Produce process
I . Before produce extruding filament, we will dry ABS and PLA for a enough time (3-5 hours).
II. Mix with colors masterbatch or colors powder, all which .certified with ROHS.
III. Adjust temperature and dragging rate , make filament diameter range at 1.6-1.8mm/2.9-3.0mm, roundness +/-0.05mm, each spool net weight 1kg+/-0.05kg
IV we put all filament spool in shelf, different kind in different shelf, all categories arrange orderly.
2. Production quality control
I. we have diameter laser detect kits to control extruding rate on line, when diameter smaller or higher than accept range, the laser detect kits will adjust the extruding rate higher or smaller to make diameter range at acceptable.
II. Keep each record filament samples sent to customers, build a tracking able document.
III. When the filament put on shelf longer than half a year, we will dry the filament again.
3. About waste & recycle
Much time you will find some black filament is too brittle, that added and mixed with some recycle and scrap after produced.
We haven’t produced with scrap outlet, rework&recycle material, or dispose, but for quality assurance purpose.
4. Packaging
We put each filament /spool on seal PE vacuum bag, then in smaller box, then out big carton
We also have vacuum heated bag to replace of PE bag, make better avoid moisture.
5. Research and developing
We have engineers that specialty in color formulation ,plastic modification, packaging, quality control ,producing control, we can do according to your requirements .
Professional 3D Printer Filament Manufacturers
Contact Grace: 0086-13476181954 or
grace@siridiwh.com
