3D printer filaments September 18, 2012 03:29AM |
Re: 3D printer filaments October 11, 2012 01:58AM |
Re: I sell 3D printer filaments December 24, 2013 01:36AM |
Anonymous User
Re: 3D printer filaments October 04, 2014 10:56PM |
our chinese website 深圳市众景优品科技有限公司Bulk order, please contact: esunpla@yahoo.com or westyang168@hotmail.com, 3 years experiences produce, we supply high quality
and good price , we have some very cheap retails in aliexpress, for try testing, only $8/kg,exclusive shipping, total price about $28-$50/kg/roll.
We start this business from 2011 recorded on FlickrThe most stringent quality control procedures, each filament line go through over 1.85mm nozzle tube to ensure jam free,inpurities free.
There are lots of factory can do like laser detect on line,eye sight detect and hand calipter detect, but it is far away enough. For example, once find a problem and do again,how to stop the working machine,it is a long time and complex work?And, the laser detect will scan every 0.2 second, it is just 0.002 second for a inpurities which length 2mm pass,even the laser machine can catch this accident data, human can't sense it .More over, it is impossible require for a worker keeping see the laser data screen for 24 hours and no fling . So some inpurities ,knot are undetected. For every users of 3d printer know, each point of accident will make nozzle jam.
We begin to add a new procedure first in China that all filament go through a 1.85mm nozzle tube to avoid inpurities and knot.In this experient we find the inpurities are not compate with plastic resin, even once that is a tiny point ,will be detected and filament will break with stretch tensile and inertia , to make knot free and inpurities free.
We will do 10kg first and then rewind to 1kg, as show below
1.85mm nozzle tube drawing as show below:
We are a professional manufacture and factory, we do in this industrial for lots of years, no matter what problem you have , we will give you a professional assist and help. we have a group of materials graduated engineer do much professional works.
Printing suggestions
1)not required heat on bed, stick with 3M scotch blue tape or glass plate;
2)nozzle temerature suggest 210-230 degree, printing rate 75-85mm/min, not suggest faster;
3)layer thick 0.1mm+, not suggest smaller to make machine over load or shaking ;
4)suggest a extruder system with spring, TPFE tube insde aluminum or stainless steel tube o avoid heat transmit, only PLA filament is heated on the place of melted, other place of not melt should be well cool. Then PLA filament won't stop in the inject tube;
5)should clean the nozzle every short time ,clean some over heat resin carbon particle.
Above picture show the PLA raw material grade is Natureworks 4032D ,some propeties below:
Property |
Unit |
Test Method |
Test Condition |
PLA |
Tensile Strength |
kg/cm2 |
ASTM |
23deg |
55 |
Tensile Elongation |
ASTM |
23deg |
10 |
Flexural Strength |
kg/cm2 |
ASTM |
23deg |
650 |
Flexural Modulus |
kg/cm2*104 |
ASTM |
23deg |
4.3 |
Izod |
kg-cm/cm |
ASTM |
23deg |
4 |
Vicat Softening |
deg |
ASTM |
Annealed |
58 |
Heat Deflection |
deg |
ASTM |
Annealed |
50 |
Melt |
g/10 min |
ASTM |
200deg×5Kg |
5 |
Molding |
FCFC |
23deg |
0.2~0.3 |
Specific Gravity |
ASTM |
23deg/23deg |
1.25 |
For the last some years, we do hard works to improve PLA formulation to make it better suitable for more and more different 3d printer.
PLA is a crystal material, and as hard as PMMA and PC, together with absord heat will turn from amorphous in room temperature to crystal one, and will make jam when 3d print.If without a well cool patch between nozzle and extrude entrance , PLA soft point is only 50 degree, extrude to nozzle will affect by heat turn to soft, that also will jam.
We do a lots of works to make PLA less trend to crystal and less trend stick to the PTFE ,aluminum,stainless steel tube.
Choose our PLA, very less trend nozzle jam, the whole process much smooth!
plastic spool is inner hole 56mm, size is 200*75*56mm
Paper carton packaging, we have 2 kind each hold 5 rolls and 12 rolls, size is 22*22*48cm and 43.5*43.5*29.5cm
