www.pibot.com
Can be used for CNC and 3D printer, PiBot provide solutions of hardware firmware and software, special circuit designed improve the Anti-electromagnetic interference ability in CNC used better than the arduino shield.
What is it
Designed for GRBL CNC and 3D printer. link between your PC and your stepper driver drivers for stepper motors. It uses the USB port which is available on all modern computers and laptops.
Purpose of designed is for easy to connect and use by Beginner, Developer, or Manufacturer.
Some features as following:
Anti-electromagnetic interference designed for improve the stability and reliability of USB communication
One-key switch to select the fuction between (CNC running) and (3D printer running/program) model
Support 2 Extruders for 3d printer and 5 Axizs for CNC
Directly upload firmware to the board use PiBot version of upload tool and firmware, No fuss, No Strange
Clear fuction zone for GRBL CNC and 3D printer
FDTI USB communication chips compatible for Win Linux Mac
Blue tooth avaiable (optional)
No need soldering, Easy or Quick connector designed for hobbies or factories
Stepper signal output can be choose on board for "en dir clk gnd" or "en dir clk +5V"
Provide I²C interface for LCD Displayer such as viki LCD, and 20×pins interface for PiBot LCD SD controller
Provide long cables for easier building, just need plug (optional)
A variety of LED diagnostic light used to indicate status, buttom-keys speaker avaiable.
Onboard fan for mosfet cooling, raise board reliability (optional)
PiBot have experience on designed and production, server for hobbies and factory, will test one by one before shipping
How it works
Fuction Zone
pibot-controller-board-rev2-x-fuction-zone
1: Power input zone
2: Communication zone
3: Common port zone
4: 3D printer zone
5: CNC zone
6: Others zone
Wiring Diagram for 3D Printer
Download the pdf -- [
www.pibot.com]
Wiring Diagram for CNC
www.pibot.com]
Related Tutorails
Connect 3D Printer Hardware for Board Rev2.x
Configure 3D Printer Firmware (With Video)
Set 3D Printer Software
Make a Printing
Connect CNC Hardware for Board Rev2.x
Upload GRBL CNC Firmware (With Video)
Control CNC by Software (With Video)
Make a Object via CNC (With Video)
Documents and Downloads
PiBot USB Driver for Controller Board Rev2.x
PiBot 3D Printer Firmware and Upload Tool for Controller Board Rev2.x
PiBot 3D Printer Software
PiBot CNC GRBL Firmware and Upload Tool for Controller Board Rev2.x
PiBot CNC Software for Controller Board Rev2.x
Development Documents - PiBot Controller Board Rev 2.x
Pins Definitions
Specification
Main Power Input: DC 12V - 30V (12V recommend)
Heat Bed Power Input: DC 12V - 30V (Depend on the model of heat bed)
Power Inpu Fuse: 15A
Communication Mode: USB Cable or Blue Tooth
Made with 2 oz. copper 2 Layer and RoHS compliant PCB
Dimensions: 130mm × 90mm × 26mm (without fan)
Hole Diameter: 3mm
Fan Mounter Hole: 31mm × 31mm
Board Mounter Hole: 120mm × 80mm
Shipping List
PiBot Controller Board Rev2.0 × 1
Shipping Notification
World Wide Shiping
DHL: 5 to 9 days
EUB: 10 to 30 days
Edited 2 time(s). Last edit at 01/21/2015 02:31AM by abcpibot.
