HUGE PART SALE!! ENOUGH FOR 2 PRINTERS!!! March 16, 2015 09:21PM |
Re: HUGE PART SALE!! ENOUGH FOR 2 PRINTERS!!! March 17, 2015 10:35AM |
Re: HUGE PART SALE!! ENOUGH FOR 2 PRINTERS!!! March 19, 2015 10:31AM |
gmh39
So I decided to clean out my workshop and have a ton of parts and things I am looking to sell. ALL PRICES ARE OR BEST OFFER. So feel free to shoot me a reasonable offer. The more you bundle, the more you'll save!
Ok let's get to is:
Structure Parts:
1. Brand New 2020 Misumi extrusion kit. Silver color. - sold
2. Bitumen tape. Works great for dampening vibrations and insulating. - $5 - 1 left
3. Scrap 1515 Misumi extrusions. Various lengths - $8
4. 1 meter 1515 Misumi extrusions. New condition - sold
5. 5/16"-18 x 36" threaded rod. New condition - $10 for all
6. M8 threaded rod. 14" length. - sold
7. 12mm smooth rod. Various lengths. $16 for all
8. 8mm smooth rod. Various lengths. One rod has a GT2 pulley on the end. sold
9. Arcylic parts from Rapman 3d printer. Can be salvaged for various frame parts and accessories. - $10
1. Heated Build plate - $15
2. Aluminum heat spreader - $20
3. Wooden build plate - $5
4. Circular delta build plate - sold
5. Glass plate - $8
1. ATX power supply case and filament spool holder. - $10
2. Power block - $8
3. open-ended ethernet cable - $2
4. Power supply plug cable - $3
5. 6ft RAMPS USB cable - $5
6. 2ft RAMPS USB cable - $4
7. LCD screen. Bought from Panucatt with Azteeg. - $20
8. green RAMPS board with arduino and 5 drivers - sold
9. Azteeg x5. Like New. - sold
10. red RAMPS board with arduino and 4 drivers - $28
11. LCD screen with RAMPS adapter - $18
12. Misc. electronics. Has a bunch of wires, connectors, switches, etc. - sold
13. 80mm fan - $8 each, 1 left
14. 40mm fan - $5 each, 2 left
15. 2.54mm wire connectors - sold
16. Brand New RAMPS LCD with adapter - $22
1. Large box of old parts and miss-prints. Can be ground and shredded and re extruded into new filament. - $5
2. ~1kg 1,75mm Conductive ABS - $20
3. 1kg Brand new 1.75mm red ABS - $15
4. 6+ kg of loose filament. - $75
Includes:
-spooled black 1.75 ABS
-Yellow - 12.2 oz (.35)
-Blue - 8.8 oz (.25)
-Red - 1 lb 12 oz (.8)
-Natural - 1lb 12 oz (0.8)
-White - 9 lb 5 oz (4.3)
-Black - 15 oz (.4)
5. Filament shredder. I'll include this with the loose filament so you can cut the filament up into pellet sized bits for re-extrusion.
Lots of misc. hardware. Mostly M3 and M5 socket head screws and nuts. There are some bearings and various other parts. - sold
1. Linear rails. 400mm length. Set of 3. - sold
2. Delta carbon fiber diagonal rods - sold
3. NEMA 17 with 350mm TR8 leadscrew and delrin nut - sold.
4. GT2 belts - sold
5. Spool of spectra line - $10
6. 20 tooth GT2 pulleys - $6 each
7. NEMA 17 with MK8 gear - $12
8. NEMA 17 with cable - $10
9. Cable tubes - $6 for all
10. Spear fishing line (~5x stronger than spectra line). - $10
11. NEMA 17s with gears (no cable) - $8 - 2 left
1. E3D v5. No thermistor. - sold
2. J head MKV-BV. Nozzle is coming un-screwed. With thermistor - $22
3. 3mm tubing pneumatic fitting - $3
4. Extruder gear - $3
5. EPCOS 100k thermistor - $5
This is a printer I started building. It is CoreXY based using spectra line. Comes with everything you see:
-3 NEMA 17 motors.
-1515 Misumi aluminum extrusion frame
-x endstop
-y endstop
-servo for auto bed level
-RAMPS mount
I will send you the 3D files for all the parts and everything I have for the printer.
$200
As I said at the beginning, ALL PRICES ARE OR BEST OFFER. I am looking to clear stuff out so everything needs to go!
The best way to contact me is through PMs. I am located in Queens, NY, so if you are local we can work out a meet up to save on shipping costs.
All parts are sold as is.
-Greg
