Ultimaker 2 Heat Bed
Complete with Temperature Sensor and Wiring
http://www.ebay.com/itm/252287077122
Specifications :
Size : 239.5 x 257mm
Sensor : PT100B
Voltage : 24V
Material : 2mm Aluminium
This is a high quality replacement heat bed for Ultimaker 2 3D Printers. The base material is 2mm thick aluminium.
It heats up to 100deg C in under 10minutes. This heat bed comes with PT100B temperature sensor soldered on. Thermal paste is also applied to ensure good
heat conductivity from bed surface to sensor which in turn guarantees accurate reading.
Wiring harness is also included and soldered on to bed. 2 wires (Black and Red) are for powering the heat bed. Their insulation are able to withstand high temperature (<200C).
The other 2 wires for sensor has one of its ends crimped with connector that matches the one on Ultimaker 2's controller board.
There are a lot of extra work to be done if you do not have the PT100B sensor and wiring harness included. That's why we have included them here
Edited 1 time(s). Last edit at 02/14/2016 11:12PM by blomker.
